Online: devkkumar59
Changing Clutch Cable
  • Sparra
    Sparra
    Just wondering when I change my clutch cable do I loose all the gear box oil when I take the outer cover off???
    Cheers...Sparra
  • Barney
    Barney
     I have done this myself recently and if you do it while the bike is on the side stand and lift the clutch side slightly you will lose fuck all.
                                                   Barney.
  • Sparra
    Sparra
    Thanks Barney...Sounds like a plan...
  • Burnzi
    Burnzi
    Go for it Sparra did it for the first time on the weekend, softail just on side stand, maybe lost a tablespoon of oil. easy job. I wasted a bit of alfoil makin sure the oil I lost went into an Ice cream container (hear that Houndog) wasnt worth the alfoil. Cheers Burnzi
  • Sparra
    Sparra
    I was thinking the same thing Burnzi(saving the oil)...Did you get away with the same gasket or did you put a new one on???
    Cheers...Sparra
  • Burnzi
    Burnzi
    same gasket mate no leaks so far
  • Burnzi
    Burnzi
    Hey Houndog rest assured mate I did clean the ice-cream container out, bound to need it for more stray bolts from the next fix-up. Its funny the more I do to me bike the lighter it seems to feel??
  • wilso
    wilso
    ive just done mine on the wide glide - i dumped the oil first and also put on a new gasket - filled back up with fresh oil - if ya gunna put on a new cable may as well do the oil while yer at it.
