Idle Speed ???
  • the_mongrel
    the_mongrel
     Is it just me or do the new EFI bikes idle faster than the older carb bikes?
    I had a ride on my mates Softail today - Is an 99 with Carbs, and it idles WAY slower than my 2010 fatty.  Sounded a bit lumpier too.  He did say it didn't have any cams in it, but I think it may have.
    Mongrel
  • Soapbox2627
    Soapbox2627
    my 04 carby will stall at idle, unless i have riden about 50Ks,
    I asked the dealer mechanic about slowing down the idle to get the potato sound, he said they will slow your bike idle down until the oil pressure is affected.
  • the_mongrel
    the_mongrel
    So will cams help to get the lumpy (as it was called) Potato-Potato sound??
  • the_mongrel
    the_mongrel
    I am hoping my air kit and radius, and a retune with TTS will help!
  • Daggs
    Daggs
    mine idles slightly fast when i first start the bike by the time I get to the first corner or whatever its idleing quite low (for an efi twin cam) and i've never noticed it going too high or too low.
    Sure I luv the lumpy old harleys just like I did with my old er V8's and my 1st car a 6 cyl. tc cortina with the most radical cam it was an auto and i had to stand on the brakes and the accelerator everytime i pulled up or it would stall.
    The commadores i've had would stall too if you pulled up at the lights with the air conditioner on. switch a/c off nice and lumpy, switch a/c on .... stall.....
    lumpy cams and the beautiful induction sound of the secondaries opening up on the 4 barrell
    Funny thing is, the Carby twin cam's have an idle spec' of 1000 +/- 50 as well, but as it's so easy to adjust, most have
    them set a lot lower, and apparently they seem to suffer no dissastrous effects from low oil pressure.
    As you know you CAN adjust an EFI bike's Idle lower with a tuner, even though it's frowned upon, but they still don't sound the same.
    That is unless you change Cams/Comp' as has been said.
  • the_mongrel
    the_mongrel
    Ok - so all that said... how hard and expensive is it to throw some cams in?
