Online: wildchild, B0nes, WideglidingNZ, speedzter
2010 Fat Boy Gear Change
  • the_mongrel
    the_mongrel
     Hey all,
    This is my first Harley and I just wanted to know if the (what I would call violent) CLUNK when changing gear is normal?  Especially gearing down.
    My Jap cruiser would clunk - but this is pretty load - Normal??
  • Dan
    Dan
    mine did clunk a bit when I 1st got it (not sure if u would cal it violent tho?) but changed to synthetic after the 1st service and had no dramas since....
  • the_mongrel
    the_mongrel
    Hmm... It just seems like it drops in rather hard!! :(
    It is definitely more noticeable on down shift
  • the_mongrel
    the_mongrel
    Nixon, Does it do it when you are down shifting when slowing down?
  • the_mongrel
    the_mongrel
    Yeah - My first HD also... So I don't know what it should sound like!!
  • AJ56
    AJ56
    Changing Trans oil to synthetic may help and possibly adjusting the clutch. My bike clunks on the way down through the gears as well but not what I would call violent.
  • robcig
    robcig
    Adjust the clutch, change the primary oil, and use Redline Shockproof in the transmission. You'll notice a huge difference.
  • FLSTC
    FLSTC
    yep normal , although i thought the 6 speed tranny has improved a little bit since first model 07
  • the_mongrel
    the_mongrel
    Thans guys,
    Put a coupe of hundred Ks on it today. Only seems a bit clunky going back to 2nd and 1st when moving slowly through traffic.
    Mongrel
  • V2Evo96
    V2Evo96
    well they alll clunk a little anyway, but as others have said with better lubes, run it in for a couple thou k's--and the kicker is--- a really good clutch adjustment will help make the difference betweeen night and day. Also while new keep up with the slack in the cable at the clutch lever. It will loosen considerably while it's running (stretching) in.
  • the_mongrel
    the_mongrel
    Thanks for the info guys.
    Great forum with heaps of helpful info.
    Mongrel
  • Taffymarsden
    Taffymarsden
    Both mine clunk and I like it. Hey its a Harley and some traditions need to be maintained.
  • robcig
    robcig
  • the_mongrel
    the_mongrel
    Yep mine does that too, but when it is warmed up and you are say coming down from 3rd to second as you approach an intersection, does yours clunk when you drop it back to second??
    Mine makes a sort of Clunk-Bump sound!! There is definitely two clunks. Almost like it bounces. Clunk-Bump. If that makes sense!!
  • the_mongrel
    the_mongrel
    Ok so I have 700 clicks on this thing and the gear changing is still loud and clunky.
    Only between 1st and 3rd, and especially gearing down when slowing. It is really off putting as it sounds like it cant be healthy!!
  • monarofan
    monarofan
    get used to it, just normal
  • the_mongrel
    the_mongrel
    I have heard that. But how can it not be doing damage. It sounds like metal slamming into metal!
    I am trying to be funny... just trying to understand how the gearbox works.
    -J
  • beagle
    beagle
    Does your clutch cable have about three mm slack at the lever end. If not adjust it to that gap or a tiny bit smaller and see if it helps, but ensure there is still some free play at the lever end. The transmission oil needs to warm up a bit and don't change down like on a japper. These things don't have slipper clutches. Just take it nice and easy. They take a few thousand K's to settle in. Mine has 20K's on it and still clunks when I'm not concentrating on what I'm doing with the gear change and clutch shift not happening together, which is often. The more you think about it, the crazier you'll become...just ignore it.... it'll go away...
    Just a thought, it could possibly be your riding style ?
    Not trying to state the obvious, but something you just do instinctively, you match revs with road speed and gear selection.
    It is even possible to change gears fairly smoothly without using the clutch.
    Do you blip the throttle on down change ?
  • the_mongrel
    the_mongrel
    Thanks guys,
    I have tried to blip the throttle on down shift, but it does not seem to make a difference.
    BEAGLE - When you say "Dont change down like a Jappa" what exactly do you mean?
    I will have a look at the clutch adjustment too.
    Thanks
    Mongrel
