Vance and Hines Muffler help
  • nobody
    nobody
    I think I would buy the baffles,without baffles you will most likely find that the pipes will give off a crackling sound..........ever heard shotguns.The baffles with help reduce this and add a little backpressure,which will help your torque.
    nobody
    Skull , The baffles will help, You can also install torque tubes that go between the head and the pipe, They work great to get back back presure, I would also check your plugs ,the bike will be very lean with a open exhaust, I tried my bike with open pipes once , the thing wouldn't rev over 4000 ,also popped and farted real bad, Im never doing that again
    JP Cycle lists Baffle P/N 440-395 $26.99 us or P/N 441-019 Baffle with Billet End Cap $38.99 us each
  • 08streetbob
    08streetbob
    where did you get them from for $500?
  • nobody
    nobody
    Hey Skull
    Glad that things worked out as I mentioned they should.The baffles just take the edge off the sound and get rid of the crackle,and make the bike more rideable in my opinion.Glad things worked out
    nobody
  • OzHog
    OzHog
    Just added the quite baffles to my Staggered longs.
    Easy as pie.
    Took about an hour as I didn't really know what I was doing.
    So that was 50 Mins for the first and 10 mins for the second. :-)
    Sound is much better.
    Low loud rumble.
    That ear piercing crackle has now gone and they are still plenty loud.
    I would recommend to anyone who wants to go with V&H pipes.
