Clutch spring 883-1200
nhb006
$40 - $60 from the dealer spring...
VERY noticable difference in hand pressure required to move the lever....
Clutch is rock solid...
nhb006
Oh, I've got the SE spring.
grafpak
i fitted the 1200 clutch spring when i did my engine upgrade ......i asked about the s/e spring and got told not needed unless going over 100hp
i did actually pay to get the clutch spring fitted as you need a special tool i paid $200-00 supplied and fitted 1200 spring is heavier than 883 spring but told s/e one is heavier again...
