Derby cover
  • Choco
    Choco
    Ok got a Wille G Collection timing cover last week for my bike as it's pay week coming up I like to get the matching derby cover now here is my question if I stand the bike upright ( use a block of wood under the sidestand ) and remove the old derby cover will I lose any oil from the primary and should the derby gasket be replaced as well cheers.
  • kingchops
    kingchops
    You will not lose any oil if you stand the bike upright.  It's recommended to change the gasket, but if it looks in good nick, I've always re-used mine.
  • WWW.AJ
    WWW.AJ
    Does your bike have a Gasket or a square " o" Ring ( Quad Ring )
  • LukeHarley
    LukeHarley
    Me and a mate did his last week, leant the bike a little past upright to be safe, no oil lost.
  • Blandy
    Blandy
    Hi TC883
    I've got an 883 Iron and have been thinking of getting a side mounted licence plate as I hate the way our rear mounted plates spoil the great chopped line...  Do you get any grief off the copper's? I heard they can hit you with 2 points and around a $300 fine?
    Also does anyone know what size Allen key is used to get the timing cover off? I've tried 3/32 and 5/64 but don't seem to fit properly, also tried a metric 2 and 2.5 but no joy?
  • Blandy
    Blandy
    Thanks TC
    I've just ordered the silncer grips and footpegs from fraser, they said that they can get the side mounted licence at around $250? Thought about trying to get it from the US with the $ almost at parity...
    Did you fit it yourself or get your dealer to do it? Looks great! I also thought that if I get pulled then I would try and get some sort of an extention bar to move it closer to the back. The law says something about it being visible at a 45 degree angle from both sides, might work.
    Thanks for the torx size, I bought a set the other day and will try it now.
    Cheers TC
    Blandy
  • Taffymarsden
    Taffymarsden
     After pipes I reckon the #1 derby cover is the best extra for giving the Iron a touch of class, and it's cheap compared all the other bits that end up mysteriously on your ride.
  • Blandy
    Blandy
    Thanks for the heads up TC, I'll check that out and fitted the timing cover no probs with the T15 this morning.
    Blandy
  • Blandy
    Blandy
    Hi Guys
    I've just recieved the Black #1 Derby for my 883 from the US. About to go to Bunnings to get the blue loctite. Just wanted to make sure before I start undoing the bolts that the oil isn't going to piss out everywere...  So standing the bike on a block to keep it level worked?
    Blandy
  • Spoook40
    Spoook40
     Hi AJ and all, this my first post. Great site and read, thanks to all. Just wondering re the derby gasket whether I have a "square" one or not and whether I should change it when I do the primary fluid. My gasket is like a disc in that it is "solid" with no middle hole, just the bolt holes around the sides. Should this be changed as it may have copped a lot of pressure or don't worry about it? Bike is a 95 Superglide (evo). Cheers
  • 883n Harley Convert
    883n Harley Convert
    Got the Willie G gear on my Iron, took about 5mins to do the points and derby covers!! Actually had the apprentice (my wife) hold the bike up straight whilst I changed the derby, she did a cracking job!!
