vance & hance big shots staggered
  • FatboyGooch
    FatboyGooch
    gday same idea as humongus, spent my tax return money last year on a 42mm mikuni carb for my 04 fatty . I have had my heart set on a set of vance & hines big shots staggered  for this years return. currently running 2 into 1  supertrapp muffler great performance pipes . but  looking for a different look and sound . looking to sell pipes to ,Need someone to supply new pipes . fit and retune carby, how much would i be looking at ?. baffles in or out ? cheers vinny
  • FatboyGooch
    FatboyGooch
    Thanks for your quick reply and advice. what  do they mean by the 02 bungs .
  • FatboyGooch
    FatboyGooch
    Thanks for your reply nixon. if i can get that price in Geelong  closer to home . cheers
    Did you have to tune the 42 Mikuni when you fitted it ?  Chances are it will be fine with the new pipes.
  • jacks
    jacks
    Save money and buy O/S....I purchased V&H straight shots and saved over 50% delivered to my door in 5 days...they are easy to fit (come with instructions for the novice) the stealers are just manic with prices charged!! (mandmcycles.com) get a quote...what can you lose???? (ensure that you get the quiet baffles, they drop noise 3db and sound deeep) as previously mentioned..j
  • FatboyGooch
    FatboyGooch
    thanks for reply and advice
  • FatboyGooch
    FatboyGooch
    thanks jacks I will see what i can come up with
  • FatboyGooch
    FatboyGooch
    thanks Quack I have taken your advice on board.
  • Wallah
    Wallah
     I've got a set of chrome V&H big shots staggered if anyone is interested in buying and installin themselves. Only done 1500k's, off my '09 deluxe.
  • FatboyGooch
    FatboyGooch
    hello jacks checked out web site can save around $350 on parts compared to dealer in geelong.They have handle bars brand name Chubby p/n w0508  need some guidence on bars as well bike has covered in freight train look with cover over middle of handle bars so risers are out of the equation.dont wont to change this look. would like to gain a inch or two to feel bit more relaxed.nothing to wide dont wont to change lenghs of cables and wiring any ideas thanks for web site they have been quick to reply with quote.
  • FatboyGooch
    FatboyGooch
    Thanks for advice on  mandmcycles site jacks . ordered my pipes today along with quite baffles . Will have a go at fitting myself. " Cheers" Vinny.
