Online: beaglebasher
Will 883 low rear shocks fit on the Iron 883?
1/3
  • SIR883
    SIR883
     Could not find anything on any forums regarding this..
  • SIR883
    SIR883
    Found the answer. they do.
  • billfish
    billfish
    Hey Oliver. hope the shocks are doing you well. Thanks for following through.
    Duane
  • TC883
    TC883
    Sir883. I f you can, please post up some pics of your Iron with the 883 low rear shocks. I am interested to see how it looks, and hear how you find it for cornering clearance. Just using you to do some research if that's OK.
  • SIR883
    SIR883
    Yeh Thanks Billfish. They were exactly what i was after.
    TC, Yeh mate...i will post pics up this week...They look great on the bike! those stock shocks on the OZ spec iron make it look horrible! could not stand to look at the back half of the bike!
    Ride is the same....went for a long ride yesterday and did not scrape the foot pegs at all. But it will happen. My mate riding behind me said i had less than an inch clearance on some corners.
  • SIR883
    SIR883
     Finally got the pics up. Sorry for the crappy pics. Were taken from my iphone.
    Big difference in feel and looks! this should be the first mod for all OZ spec irons!
    Stock shocks below.
  • Birch
    Birch
    I have a pair of barely used Low shocks if anyone is interested. An even hundred bucks would make 'em yours.
    I live in Rosebud, Victoria.
  • zoi84
    zoi84
    Anyone else have a pair of Low shocks for 883 Low for sale please let me know!!!
  • zoi84
    zoi84
  • SIR883
    SIR883
    Clearer pics
  • zoi84
    zoi84
    SIR883, nice looking Iron mate, great job. Mate, what size are your Z bars? And would it be possible to twist them a little bit closer to ya , so you have a bit of angle in you elbows. Also are your arms straight in front of ya, or slightly hanging?
  • SIR883
    SIR883
    thanks mate, theyre 10" bro. Yeh you can, just loosen the bolts on the clamp and adjust to your liking.
    My arms are out in front with a slight bend to my elbows, they feel great...
  • SIR883
    SIR883
    thanks again, there are alot of other awesome irons out there on the net, still got a few mods to go.
    I got the bars custom made, find a picture of what you want and contact Dennis 0438 422 202 at SPS fabrication (website below) tell him "Ollie told me to call you". Top bloke. he made mine for $150. Alil cheaper than ebay after postage.
    http://www.spsfabrication.com.au/
    Anyone who reads this can contact Dennis if you want handle bars made. 0438 422 202 he is in Sydney.
  • TC883
    TC883
    Sir, top looking Iron mate. While we are talking about inspiration - I have just bought a set of 883 low shocks from Birch. Your photos sealed the idea for me, so thanks heaps. Can't wait to get them on the bike. Will post pics when done. TC
  • TC883
    TC883
    Only luck I have ever had! I have been watching the for sale ads on here and ebay Aus for a while. Post up on the wanted section if you are after them, you never know your luck. As for the V&H SS with no other mods....not really sure. I was only after sound and appearance. I really like the stock tapered slip ons on the Iron. Looked around at other slip ons, and the only ones I liked were tapered and looked like stockers...so I got hold of a spare set and drilled them out, as per Damon's technique. Bike runs fine, no problems. All of the advice I got said that slip ons and no other mods were fine, no need for remapping. As soon as you add an air cleaner, it is time to remap (fuelpak, Screaming budgie, power commander etc). Most advice also seems to say if you go to a full system like the short shots you need to remap. I would be wary of not remapping after fitting the short shots....TC
  • zoi84
    zoi84
    Yeah that’s what I heard as well and that all than becomes quite an expensive exercise just for sound and appearance. Anyway thanks for an info n advice, keep up good work and ride safe mate. Post some pic. when you have a chance. By the way what mark would you give for the sound of drilled mufflers from 1 to 10. 1 being stock and 10 being V&H SS? Cheers.
  • SIR883
    SIR883
    Zoi84, im just getting v&h slip ons from ebay and getting them powder coated matt black. Just as TC said no need for new filter fuel pak etc etc..but if you dont mind chnaging those things go for it.
    TC, yep you are lucky! you know how long it took me to find a seller? ages. kept checking ebay...wasnt keen on buying progressive shocks 412, it was costing me over 300 bucks after postage, thats as much as the v&h slip ons im gonna get soon.
  • SIR883
    SIR883
     yeh thats the only thing, the chrome kills me. i will probs get the springs powder coated soon. I knw you can take em apart...
    yep, I got the stock heat shields powder coated matt black...as i said before could not stand the chrome...i want to powder coat everything chrome in this bike. Just my taste.
    http://mandowspowdercoating.rtrk.com.au/?scid=6746&kw=3948848 check em out! top blokes cheap as.
  • SIR883
    SIR883
    Bucket,  when you say 'yet' are you anticipating there will be problems later on??
  • Birch
    Birch
    Yeah, I drilled my pipes too, and am pretty happy with the sound (especially at the price!). They sound good, but not too loud, and when I was pulled over recently , the cops did not even mention them. Had enough police trouble in the past to last a lifetime, so I was happy about that.
    Also have a K&N filter which made no noticeable difference, but at least it is the last air filter I will have to buy for the bike.
1/3
