Online: beaglebasher, DIVOT
Pics of my 08 883c
  • kingchops
    kingchops
    86juc,
    The blue and black combo is great.
    Hey I noticed you've got the chrome engine covers, they look great, are they slip-ons? If so which ones did you get?
    The 1200c has the Horn on the left hand side, It is easy to fit one on to your bike ,
    You can pick up the HD Cow Bell horn covers on Ebay for about 5 bucks, you will have to change your Choke bracket to one from a 1200 c as the horn mounts to it ,
    I dont know why the 1200 c has the Cow Bell Horn and the 883c dosen't,
    I geuss the little engine hansn't got the power for the extra weight..................
  • 86juc
    86juc
    Yeah kingchops the engine covers are slip on's from www.robscyclesupply.com ebay store, all up for all 3 covers was around 200 bucks delivered from US.
  • outbak
    outbak
    Nice bike...
    For my 883C i got a genuine HD horn  kit  but  the horn sat way too low for my liking and the mounting bracket had a daggy bit hanging off it to fit models with a choke.   So i modified the mounting bracket so it sits "up" rather than hangs "down" and i cut off the daggy choke bit.  i bought the horn kit off Ebay from the US.. it cost about 80 dollars (with shipping) if i remember right.  It might pay to note that the kit requires the tank to be removed, so its not a 5 minute job.  here is a pic of the result...
    http://i285.photobucket.com/albums/ll47/outbak/P1010012_2.jpg
  • Bernie
    Bernie
    Outback, that pic of you bike shows a pretty neat detail, you have any other pics?
  • outbak
    outbak
    Bernie,   i posted some pics a couple of weeks ago..  titled "2007 Sportster Pics" .   The avatar pic  i use  is from a photo a mate took for me at our recent show 'n shine.   He said it was the  only one of my bike that turned out any good..
  • outbak
    outbak
    The wiring harness connected under the tank if i remember correctly..
    OF...  Sorry but i havent been online for a while and will chase up a pic of that bracket if it is still needed .
