Online: softfat
ridin sunnies
  • evilsim
    evilsim
    Sounds like a winner Crusty. Might chase some up with the clear lense for the odd dark ride.
  • V2Evo96
    V2Evo96
    Hey Crusty,
    excellent and thanks for putting this up. I've been using wrap around tinted from work but the foam seal sounds great.
  • Hound_Dog
    Hound_Dog
    Where did you get them from mate?
  • Burnzi
    Burnzi
    Thanx crusty and bonkerz will be lookin at these for sure
  • Milo
    Milo
    Thanks for info Crusty, ordered a pair with some replacement lenses on Friday. They said they have the removable closed cell foam seals but I couldn't find them on the site. Comments from Romactrading was that the darker lenses are normally used for welding. Cheers.
