Got caught in the rain - Dirt Road - Cleaning tips?
  • Firey
    Firey
     Iv'e been caught in the rain before, not like this though, I rode from Nerriga to the Kings Hwy this morn in the dirt, clay -  my bike is just caked in crap - I hosed it off - truck washed it and its still not good enough - any tips?
  • toxic
    toxic
    soft cloth & hard work ......
  • Poddy
    Poddy
    I would use truck wash and lots, lots, lots of water, make sure the truck wash doesn't dry on the bike and she'll be right
  • Cubicinches
    Cubicinches
    OK Who else doesn't know how to clean a motorcycle?  Cmon put ya hands up !!!!!!
    Rats are the ultimate custom cycle
  • Tassiedave
    Tassiedave
    1 get beer
    2 let bike cool
    3 more beer
    4 Bikini girl washes bike
    5 more beer
  • Farmer
    Farmer
    i use S100 all purpose cleaner and a high pressure sprayer on my HOG. I too was take on a dirt road much to my dismay, especially after i had spent 4 hrs the previous night detailing it. It cleans it ok, but a bit of elbow grease is needed to get the nooks and crannys. I also use S100 engine bright for the engine block to keep it nice and black
  • Firey
    Firey
    Thanks for the help Gents!! Ha - had a go with a bit of degreaser - then some Autosol for 2 hrs - have another go tomorrow night, yer Crusty send her over tomorrow so when I get home from work its all done - and she has earned $500 for cleaning and polishing the bike for me.
    If its raining tomorrow - there is a BBQ and free piss on at my place!!
  • LOFTYBOB
    LOFTYBOB
    Buy a new bike
  • Burraburra
    Burraburra
    Ask the Gubberment to tar the Nerriga Road..................................................Ha fuggen ha.
  • motor_head
    motor_head
    This is what ya do.......get yaself some ct-18 and a 1 litre hand held squirt bottle and a pair of sunglasses, put about 1 cm of ct-18 in the squirt bottle and top up the squirt bottle with water then spray the whole bike.....let dry for about 10-15 minutes or until ya bike looks like a rat bike, put on the sunglasses and hose the bike off  ( pressure cleaner should not be needed but might be helpful ) .......problem solved......ps,  if you forget to put the sunglasses on the chrome bits are gunna blind ya.
  • Firey
    Firey
    Cheers Farmer and Motor Head - I did that - it was much better - then I diluted a bit of Degreaser and tried that.
    I just finished washing the Saddle bags, Sissy bar, boots , jacket, leather pants and seat - then hit them with the leather dressing - all good.
    The bike is going to take some cleaning - Farrk Nerriga - a good night though!
    I heard they are going to have the road all tard by next year
  • ==ShaDoW==
    ==ShaDoW==
    I thought you went out in the rain to wash your bike? maybe I am doing it wrong, JK had the same issue with mine when i road over a long strech of road works covered my bike in all sorts of crap, all i did was hit it with the hose when i got home and left what ever was stuck there on the bike, with the weather out here its gonna dry and drop off anyway so why worry.
  • BURTO
    BURTO
    Hey Firey, sounds like I missed a "fun" ride!................ Not so sorry I couldn't make it now!
  • Firey
    Firey
    Took some doing~!! its back - fuuuccck Nerrriga
  • SuperGlide
    SuperGlide
    Good work, Yeah my OCD helps with cleaning big time, but I was spewing Satdee spent 4 hrs cleaning/polishing, thought you beauty after a Major like that I usually don't need more than a quick wipe/detail for 2 months, then Sundee out past windsor got caught on dusty unsealed roads, then 10 klms up road they had hosed it to stop dust so copped the mud. Ah well, it's all good fun. Just thrash the fucker now for few weeks and then back onto the toothbrush and Mr Sheen (lemon fresh)
