Online: John.R
Ultra upgrade
  • CHARLIE
    CHARLIE
    Was time to look at the chain tensioners and yes they were stuffed 92,000ks second set,first went at 51 thou,so had fitted SE203 cams, lifters, bearings, and so on,am told the 203s will make a big differance two up as we are going to isa for the hog rally anyone running these cams and can let me know what to expect as was told to fit 204 but went for the 203 who knows.Asked the mechanic if i needed a download and he said no has mufflars and air cleaner done that's all me thinks Hmmmmm is he correct?
  • CHARLIE
    CHARLIE
    EFI / 03
  • CHARLIE
    CHARLIE
    DEALER DOWNLOAD.
  • CHARLIE
    CHARLIE
    Tks Hogbag pulled the rear plug after 200k run plug looked good right colour,so will leave it and check it after i get back from ISA the 203s work well fitted new lifters and bearing kit and new tensioners so all is good.Charlie
