Online: speedzter
Making custom bars
  • DASH71
    DASH71
    Hi all,
    I'm considering making a set of Z apes for my ride. But I was wondering if anyone has any tips or links on material and techniques, etc.  I have searched around but with no luck yet.
    Had a lot of experience with Mild steel and MIG welding, just not sure if mild steel is the right material.
    Thanks in advance
    Dash
  • DASH71
    DASH71
    Anything guys?
    I know there are stainless bars out there as well as different alloys, but my main question is whether or not 1 inch mild steel tube (varying wall thickness) from the local steel joint will cut it.
    Any advice would be appreciated.
    Dash
  • Daggs
    Daggs
    I used seamless steam pipe.... the price was right.... nix.....
  • Brucey
    Brucey
    Mate steel tube from the local steel merchant will not cut it CREW tube is for funiture (Cold rolled electric welded) elongation is around 12%
    Hydraulic Dom tube is like plasticine it is Dom (Drawn over mandrel) but it is fully annealed 25% elongation
    This place is the best to get hold of some 4130 Chrome moly is http://www.racetechsteel.com.au/site/index.php?option=com_content&task=view&id=74&Itemid=96
    It will not be cheap and do some checks on welding it properly (heat inputs pre and post heat treatment ) but hey there handle bars i for one would not like to muck up and have a bar snap on me or have a bit fracture
    Good luck with it mate
  • DASH71
    DASH71
    Thanks for the info boys...maybe I will make do with what I have.
    Dash
  • Thomo_Baca
    Thomo_Baca
    Hydraulic tube is spot on for inside diameter only
  • DASH71
    DASH71
    Thanks for the info... I'll let you know how it goes.
