Online: John.R, Hilly
cam info & suggestions
  • rumman
    rumman
    got an 88b as well and plan on changing to gear driven cams in the future ,so would be interested to see what everyone recommends as well.
    The questions you will get is what bike, and how do you like to ride ?
  • Peter L
    Peter L
    I've got an '04 Dyna that I am planning to swap the cams and complete a tidy up of the heads. I'm planning to use Andrews TW37b cams and change the lifters. THe heads will come off at the same time so I should be able to use the original push rods. I plan to take .30 thou off the heads and polish up the inlet and outlets. I already have the 42 Mikuni, V&H Long Shots and Big Sucker air intake. Shop around locally, but at the end of the day gear out of the US is pretty hard to beat, price wise.
    Lockie
  • graeme
    graeme
     i have upgraded to 95 kit 211 cams new cam plate and oil pump hi comp pistons 42mikuni and heads goes well done 4000kms since rebuild old spring tensioners half worn after 53000kms upgrade kit has hydralic tensioners
  • Firey
    Firey
    John, H.d parts (orders@zanottimotor.com)
    John from the U.S was good to me - once you organise the parts you want - give them a try as well.
    Ask them about every cost from there door to yours though.
    I'll throw a few ideas out there for you to research, guessing that your not touching the top end at all ?
    Andrews TW26 or TW37, SE-204 (chain), The last two would do better with a little more compression.
