Latest Mod, who can spot it?
  • nhb006
    nhb006
  • nhb006
    nhb006
    Illegal huh? - Really, you don't say... All the fun stuff alway is, anyway, plate has been like that since I brought the bike last year... - Was the first mod I did.
    Strangley enough, I've never been pulled over...
    Keep guessing...
  • Taffymarsden
    Taffymarsden
     Pulled up beside a bloke with his plate fitted like that and asked him how he got away with it. He said "I figure I'll get away with it for as long as I get away with it". Someone on this forum got done for a side mounted plate the first time he took the bike on the road and was not a happy fella. I think it looks great and you see a few around so I guess it depends on the luck of the draw - some PC Plods are more reasonable than others :) Nice work.
  • nhb006
    nhb006
    Thanks Taff. - Being a fellow Iron owner, can you spot the mod?
  • Taffymarsden
    Taffymarsden
     Aha! The amber lenses are missing. How? The covers looks the same.
  • nhb006
    nhb006
    Lol. No, they are actually tinted... (Spray on)
    Ok, I'll give you a clue..
    Look at the struts holding the tail lights closely...
  • Taffymarsden
    Taffymarsden
     You win. I surrender. Come clean.
  • mintpaul
    mintpaul
    Shorten'ed them :)
  • Taffymarsden
    Taffymarsden
     Hey brilliant. I won't be taking a rusty old hacksaw to mine though!
  • nhb006
    nhb006
    How bout a 5" grinder then? - Thats what I used. :)
    Mask up the tail lights, Spray the outside with Night shades. - If you do the right prep & paint when its warm it will turn out MUCH better than you think. - Mine have been done for quiet some time now. - Several months, finsih still perfect.
  • djs
    djs
    Hey,
    Yes you are right about using nightshades only when it is warm!  I did my fronts in cold weather and the finish didn't come up to good... thought it was the paint at first then I tried again on an old car indicator lense in a heated room 22-24 degrees and it came up great.  I am going to buy new front lenses and redo (and also do the rears) in spring/summer.
    One of my mates side mounted his number plate on his yamaha (he made sure he put a white light on) and funnily enough he has been pulled over by the police quite a few times now but they never say anything about the side mounted plate.  And you definately can't see it from a 45 degree angle!   Instead they pull him over for not having a front wheel guard and a few other dodgy things he has done to the bike.  He has never been booked... only given warnings.  We are in the ACT.  Apparently here they can't actually book you for a lot of illegal motorbike mods... only give a warning.
    Dan.
    If you let a few people get away with things then more people think its okay, then one day you get to hand out lots of fines, instead of just a handful.
  • nhb006
    nhb006
    I'll be sure to keep that in mind...
  • grafpak
    grafpak
    45 deg's from 20m's behind the bike in vic...
  • SJ
    SJ
     Grafpac...
    Its 20m behind the bike, at either 45 deg in vic?
    Most side plates would be fine then right?
    I assume the plate still has to be parallel to the ground though (not upright like in thsi pic).
    Just making sure as I have been trying to find this without success....
