After market clock installation
  • lance100
    lance100
    Guys, I have a 2010FLHRC and ordered a fork cover clock from the US that arrived yesterday.  It swivels out from the cover that sits where the 'lock/unlock' cover normally resides on the Road King stem. The instructions require removing the cover and screwing in two screws under the lock/unlock cover to secure it.  When I removed the cover, I realised that  'headless screws' are used on the international models rather than just the two phillips heads that they use in the US.  Does anyone know how to remove them and will the phillips heads they supply fit?  I see that I would probably have to have them drilled out - will the stealers do that for you?  Other than that I might have to use a metal glue to put the clock on the stem, though I am not in favour of that for obvious down track removal reasons.
  • lance100
    lance100
     HogBag, thanks mate, good advice.  Lance
  • lance100
    lance100
     Hog, it worked and thanks mate
