Online: B0nes, Stuart
Cam Bearing Removal/Installation Tool
  • BURTO
    BURTO
     Have been trying to buy a Cam Bearing Removal/Installation Tool from Gary Beatty in the States, but his email address bounces back!  (beattygw@scbglobal.net)
    Anybody know how to contact him or where to buy his tool or similar.
    I'm after a tool that both removes and instals the inner cam bearings in a 2007 up twin cam, as opposed to a separate tool for each.
    Thanks, Burto.
  • BURTO
    BURTO
    Thanks Scotty, just had a look at the Mail Administrators email and realised that this was one that bounced 5 days previously.
    I had since sent another because I checked my "sent emails" and it was not there! This one was sent to the correct address. Must have copied and pasted from a different source!
    Still haven't heard back though.
  • BURTO
    BURTO
    Ah yes! Forgot about the July celebrations/holidays.
    Have got all the other parts etc. for the cam swap on the way. Cant really afford to spend $170US + shipping for the two tools.
    Don't suppose anyone on this forum might have the tool/s to sell or hire?
  • BURTO
    BURTO
    All good!
    Gary Beatty got back to me, tool on the way.
    $135 AUD delivered.
  • shfunky
    shfunky
    Hey Burto, what's the go, sounds like a good price, does the one tool do both??
  • BURTO
    BURTO
    Funcky, yes mate it does. Check out this link to another US forum.....
    http://www.hdforums.com/forum/touring-models/516656-gary-beatty-inner-bearing-pulled-and-installer-tool.html
    Should tell and show you all you need to know!
  • shfunky
    shfunky
    Thanks Burto.
  • BURTO
    BURTO
     Used this tool today to replace cam bearings.
    Big thumbs UP for this tool!
    Quality and easy to use...........replaces 2 other tools!
  • Burraburra
    Burraburra
    Hey Burto
    How many Ks does ya bike have up?
    Why did you replace the cam bearings?
    Im looking to learn me anything I can :)
  • BURTO
    BURTO
     Burra,
    Fatbob has about 7500kms up since new in late March.
    Replacing bearings not cause theyre fucked, but I replaced cams (woods 6) and might as well put good bearings in at same time. (highly recommended!)
    Did the same in my 85' evo last year!....... when will Harley finally get with it and install quality bearings to start with????? 25+ years and they still dont get it!
    If yours or anyone elses question is " how are the cams?"............answer is..............FUCKYEAH!!!!!!
  • Burraburra
    Burraburra
    Burto mate,
    Thanks for the information.
    You have won me over on replacing my cams.
    Much appreciated.
    Cheers Big Ears.
