Changing Rear Shocks, Softail
  • Tassiedave
    Tassiedave
    I am going to put my new shocks in on friday, just looking at the manual, it refers to using a SNAP-ON-ADAPTER, Part No. SRES24. as you can see below. Is this the way it has to be done or can I get a spanner onto the bolt?
    Dave
    REAR SHOCK ABSORBERS 2.26
    GENERAL
    The rear shock absorber on Softail motorcycles is not repairable.
    If the shock absorber becomes damaged, it must be
    replaced as an assembly.
    NOTE
    See 1.16 SUSPENSION ADJUSTMENTS for information
    regarding setting up the suspension for carrying cargo.
    REMOVAL
    1. Using a suitable lift, support motorcycle under frame until
    rear tire is slightly off the ground.
    2. Remove bolt and washer (1) attaching shock to rear fork.
    NOTE
    Snap-on adapter, Part No. SRES24, is necessary to gain
    access to shock bolt.
    3. Remove flange locknut (5) and washer with grommet (4)
    at front of shock.
    INSTALLATION
    1. See Figure 2-108. Place washer with grommet (4) inside
    frame. Install bushing (3) over stud end of shock. Insert
    stud end through keyed frame tab and loosely install the
    flange locknut (5).
    2. Coat shoulder of bolt (1) with LOCTITE ANTI-SEIZE and
    threads of bolt with LOCTITE THREADLOCKER 243
    (blue). Insert bolt and washer (1) through shock end.
    Pivot shock absorber to align bolt with hole in rear fork.
    CAUTION
    Softail shock absorber bolt torquing procedure requires
    the use of a SNAP-ON-ADAPTER, Part No. SRES24.
    Since the adapter lengthens the torque wrench, torque
    must be computed with a TORQUE COMPUTER, Snap-On
    Part No. SS-306G.
    3. Tighten rear shock hardware.
    a. Tighten bolt and washer (1) at rear of shock to 115-
    130 ft-lbs (155.9-176.2 Nm).
    b. Tighten the flange locknut (5) to 32-39 ft-lbs (43.4-
    52.9 Nm).
    4. Adjust both shock absorbers equally. See 1.16 SUSPENSION
    ADJUSTMENTS.
  • wazza-in-oz
    wazza-in-oz
    You can get a spanner on but you need to lift the bike up high enough on a stand so you can actually get leverage on the spanner if that makes sense. The adapter they are talking about lets you access the shocker bolts and attach a breaker bar. The shocker nuts are pretty tight and you will need a bit of force to undo them. I had my bike up on my repco bike lift and used an ordinary spanner and used my foot/leg to push on it to break em loose. Good luck. Pretty easy job once to get the bolts loose.
  • Tassiedave
    Tassiedave
    Thanks Wozza, I doing it on a mates lift so should be fine.
    Dave
  • Sparra
    Sparra
    Are the shocks on a Softy at there softest when you can see all of the bolt thread or is that when they are at there firmest???
  • Tassiedave
    Tassiedave
    Yes I think so.
    see below, out of the instrutions14 / ". Do not
    6. Test ride the bike and
    make further adjustmentsifnecessary.
    Note: Adjusting the
    preload does
    not
    change the shock
    length.
    Note: Maximum preload is
    reached when the locknut
    and adjusting plate are
    turned to the end of the
    threads (no threads showing).
    This distance is
    approximately
    turn the locknut past thelast
    thread!
  • Tassiedave
    Tassiedave
    Fitted the shocks this morning, What a piss easy job, only took one beer. Now I have Chrome under the bike as well.
    Dave
