any damage done
  • ireland
    ireland
    Have just fitted stage 1 air filter to go with my se slip on pipes.Next stage is tts or septs have not decided yet.If i run the bike for a few weeks without tuner will i do any damage only talking about afew hundred klms. thanks.
  • kingchops
    kingchops
    I'd put the stock air filter back in untill you get a remap done. Without a remap you will be causing high temps in your engine by having a lean air/fuel mixture and both high flow pipes and air filter.
  • evilsim
    evilsim
    Good advice ...
  • ireland
    ireland
    thanks
  • ireland
    ireland
    done about 50 klms on stage 1 filter ,fuel tuner arrives next week thanks for the info.
  • matt08
    matt08
    i have been told that it will be ok for a little while as long as you dont try and flog it
  • ireland
    ireland
    will be sorted soon thanks Matt
  • mintpaul
    mintpaul
    WHat tuner did you end up getting?
  • ireland
    ireland
    went for the screeming eagle it was cheaper than the tts ,was originally going to go for the tts but i dont have a laptop so went for the screeming eagle probably better for warrently as well.how is your tuner going?
  • mintpaul
    mintpaul
    I went for SE for the same reasons as you.
    I haven't installed it yet, still deciding on what intake to get.
    Also I have to find out a good independent mech that can install the SE around Brisbane.
