How long before fuel goes "off"? ie if I have fuel in my tank and leave it for 3 months.... is it still good fuel? what about 6 months?
Thanks for any info.
This short publication is worth a read.
www.power-equipment.com.au/article.asp
Yea mate drain ya fuel to be on the safe side, I had a bike that sat in the shed for a year with a full tank, when i finally decided to pull it out i couldnt for the life of me work out why it wouldnt start... pulled the whole thing apart untill i had a light bulb moment and replaced the fuel and KABAM!!! it started.
Have used this stuff: Works Ok.
http://www.lucasoil.com.au/content/view/19/71/
Just follow any of the storage tips on the yanky HD sites, they have it down pat.
Also would fog the engine with fogging oil or two stroke engine oils does the same thing.
