Quick Realease Brackets
  • Sparra
    Sparra
    Wondering if any one knows if you need to buy new saddle bags and back rest  for quick release gear or can you convert your old bolt on jobs to quick release with some brackets and a docking kit???
    Thanks...Sparra
  • Sparra
    Sparra
    Thanks Mate...I found a previous post that told me the same as you with the bags...I think I'm gonna have to put up with the fixed backrest...
    Cheers...Sparra
