White Wall cleaning tips required
  • evilsim
    evilsim
     My white walls ar'nt as white as they used to be ... Sponge and soapy water just smudges ...
    Please, what is the best way to clean them and tips on keeping them that way.
    Cheers Simmo
  • blueystar
    blueystar
    try jiffy and some light steel wool
  • Mako
    Mako
    Yeah i use jiffy and a wet green kitchen scourer. works great.
  • Burnzi
    Burnzi
    Best way to keep em clean Sim, do as others have said with jiff and scourer...........
    Then put in shed and dont ride Bwaaahhhaaaa.
    Like ur gunna be able to do that. Nice ride
    Good photos from when u picked er up too.
  • Firey
    Firey
    Yep - what they said add a bike jack so you can spin the tyres if you have one
  • ductor
    ductor
    degreaser and a toilet brush
  • evilsim
    evilsim
    Thanks for the tips ... will give it a go tomorrow.
  • cactus60
    cactus60
    $2 degreaser and a hose works if you do em after every couple of rides ive found.. also a small karcher high pressure cleaner gets that blue stuff they put on from new without any dramas.
  • CHARLIE
    CHARLIE
    I went and priced the cost of rep-lacing the white wall on my Ultra prices varied but around 40 to 50 dollars more a tyre so guess what black looks lovely and no more cleaning.
  • Hound_Dog
    Hound_Dog
    $2 degreaser, clean rag ( critical) and a Repco bike lift. Sweet as
  • IK
    IK
    Try abit of wet n dry sand paper. Works wonders
  • twincam88b
    twincam88b
    I used mineral turps and a clean rag. using a bike lift makes it easier.
    Im a Jiff
  • ductor
    ductor
    buy the toilet brush it saves the skin on your knuckles.
  • pistol pete
    pistol pete
    a cheap car degreaser is best ive found don't get the watery type or itll smudge get the stuff that foams when ya spray it on and use a clean micro fibre cloth to clean off no scrubbing needed make sure ya dry em after ya wash or ya get those black streaks also found it handy to clean ya exhaust if ya got side shots etc as the carbon build up blows on em after ya clean em leaving black dots all over ya wheels
  • CHILLY
    CHILLY
    Dont know how well it will work but the old ball & chain is suggesting bi carb of soda mixed to a paste & rubbed on (then washed off) would work well.
