Online: HD17, John.R, Hilly
New Bare Bones Solo
  • 86juc
    86juc
    Just installed my bare bones solo from Lepera, just wondering what to do with the protective tape on the rear guard. The tape looks crap but dont really wanna get rid of it incase i have to put the old seat back on for two up. sugestions
  • Sledge
    Sledge
     Remove the tape from your guard
    Get some more from the stealers ( about $5) and put them on the bottom of your 2 up seat.
    Cheers Sledge
  • ==ShaDoW==
    ==ShaDoW==
    I just took off pads and stuck them to the under side of the seat so when I need them they will still be in the same place they are suppose to be just upside down :-)
  • Soapbox2627
    Soapbox2627
    can you buy a "tongue" that runs from the back of the seat to the screw hole for the two up seat?
    That would cover the tape and be more decorative than a plain guard
  • Burnzi
    Burnzi
    Check out Tubz's FLSTN in photo gallery has just the thing ur lookin for maybe
