Online: Trunksie, Rextheute2022
notchy throttle
  • Kustomtown
    Kustomtown
    Just got a '09 Road King. When I want to lightly increase the revs, the throttle feels notchy/sticky.
    Not a problem when you twist the grip for normal acceleration, more when you are just 'feathering' the throttle.
    It's fly by wire type throttle....any thoughts?
  • Kustomtown
    Kustomtown
    Yes mate. It's definately internal. Probably a similar feeling if the throttle lock was tight.
  • Kustomtown
    Kustomtown
    Cheers Trev.
