Cheap $10 Mod for international rear lights
  • ==ShaDoW==
    ==ShaDoW==
    Ended up just doing temp fix as I will most likely Mod the rear end of bike one day soon, $10 of bolts and 40 mins work (took pics etc thats why it took me so long) you can veiw below :-)
  • ==ShaDoW==
    ==ShaDoW==
    adjust them again made them smaller cut half the bracket off
  • ==ShaDoW==
    ==ShaDoW==
    Ended up getting some smoked lenses as well i am happy with the look.
  • Burnzi
    Burnzi
    Good job Shadow, I had the same problem with my FXSTC I bought Heritage bags (used to have a Heritage and cant do without them) I had to use the number plate holder with the indicators in as I couldnt find another way of sorting the problem. Illegal I know but at least they r there. U should be makin em up and sellin them. Cheers Burnzi
