Air cleaner from car parts shop for Sportster ???
  • aussiesport
    aussiesport
    dude i used a ramflo oval filter on my ole skool chopt and bobbed sporty looked horn :)
  • Phillthy
    Phillthy
    I used one of them on mine.
    Have an Arlen Ness big sucker fitted and all you have to do is trim the internal ridge off and it will fit.
    Also fitted a cone shaped one, had to make a new bracket off the studs to make it fit after internal trimming.
    Only limited by your imagination and capabilities.
