Online: beaglebasher
200mm into a stock 00 swing arm will it fitHi
  • Harleydudeau
    Harleydudeau
    Hi all i,m Pat
    and i,m from melbourne
    i,m not sure if this is the right place to ask
    but i have a question about my harley
    i want to fit a 200mm tyre to my harley and was wondering if it will fit into
    a stock swing arm as my harley is a 2000 model softail std FXST
    i have had many differents answers .
    i,m hopeing some one from here can give me the right answer.
    and if i can do it what i need to do
    thanks guys
    Pat
  • Purnong
    Purnong
    Welcome to the forum Harleydude
    As Thrus7er said try posting your question in the Workshop forum, You will most likely get the right answer to your question
    Dont forget to visit the Pub as well, Gets lively in there at times,
    Oh and watch out for Jilli883, She is a lurker
  • Harleydudeau
    Harleydudeau
    Hi Scotty
    hey thanks heaps for the quick reply ...
    i have already got a set of pro-one billet rims (Storm series)
    the back rim is 18 / 5.5 hope this is the right size for the 200mm
    i just need to know will a 07 or 08 rear fender fit my 2000 frame.
    or do i have to cut my fender and widen it .
    thanks for the advise ...
    Pat
  • Tux
    Tux
