Online: baldy1450
Sportster engine compatability
  • butza
    butza
    Gday guys, anyone know if an 1981 ironhead motor will fit into a 1986 frame and on.
    Cheers .
    Butza
    hi,   you will have to stuff around with the front/ rear engine mount  use a 1983 to 85 rear mount  because that later tube type frame came out in 83  but still with the cast iron motor untill 85  + the front mounts also 83 to 85  if you get stuck i might have i  ?
