Online: Stuart
Getting a 200 under an Evo Softail
  • Bear Shoot
    Bear Shoot
    G'day everyone, I am new around here, but I have had 9 Harleys, so I am fairly educated withem! MENEEDSOMEHELPBUT! I am wanting to fit my 90 Softail with a 16x5.5 Morad Alloy Spoked Rim and a Avon 200 tyre. I have chain on it already with 5mm offset in front and rear sprockets. My guard I am fitting up is a Jesse James to suit 200. So many different stories I have heard and read! Just would appreciate the simple easy and cheap alternatives to get it in there!
        Cheers, Bear.
  • Burnzi
    Burnzi
    Hey bear shooter, Are bears cops hmmm. PM Angry1 or Walka they have the knowledge. I am waiting for finances to improve so I can do the same I have a brand spanker 200 Avon if ur interested I am goin with a 180 so I need to get rid of the 200 that I bought with wheel. Cheers and post pics of ur progress. Burnzi
  • Bear Shoot
    Bear Shoot
    Thanks for the reply Burnzi. I will let you know a bit later on if I need your tyre Fellah. Excuse my ignorance, but can you explain to me how to get in contact with PM Angry1 and Walka, if you think they might be in the know.
    Cheers, Bear.
    PS:Burnzi, I am known as Bear, and I am a Photographer..............Bear Shoot.
  • Burnzi
    Burnzi
    Hey Bear To PM (personal message) go to ur Unread Messages, in there u can type in Angry1 or Walka and ask them for info. Angry has some good photos with spacer sizes etc. Cheers and good luck Burnzi.
    PS I think Angry expects a box of coronas along the way. LOL
  • butza
    butza
    Gday , you can get hold of Walka at  VPW in Epping on cooper st.
