Online: HD17
vance and hines big radius
  • Baldivis
    Baldivis
    G'day Nixon, as far as I know it depends on the dealer. Some dealers will charge you double the labour if you supply the parts. Others will charge roughly around $1150-$1500 fitted.
    It just so happens that I have a set of near new V & H big bore radius pipes, 2 into 2 for the Fatboys. At the moment I am trying to sell them for $750 so I can fit some V & H BSS's. (that I have been waiting for way too long, good ol dealers hey. I think they think they sell candy FFS?????) Anyway, where was I?
    Then if your lucky you can get them fitted for $100 at a bike shop that's not a Harley Dealer or upwards from there in the labour department...If your interested in the pipes then you can pm me, or otherwise I hope the info helps.
     Cheers.
  • traj
    traj
    hi mate ive got a set of vance and hines big radius pipes for a 2010 softail , ive hooked them up my question is what do i do with the electrial plug on the bottom
  • Magilla
    Magilla
    Cable  tie and tuck it under
  • rockyrob
    rockyrob
    Bought mine from Robos Bikes Supplies in the USA,  around $580 delivered about 6 months back, fitted myself in about  two hours including drinks breaks .WOuld like to shop local but at those prices it is too hard to knock back
  • DARKRIDER
    DARKRIDER
    G'day nixon. Check out this mob below and fit them yourself, or get the ol' mate with mechanical skills to help ya for a slab or 2
    http://www.morepowerracing.com.au/4a7p7j5511618/Exhaust/Harley-Davidson-Exhaust/Vance-&-Hines/Harley-Davidson/Softail/2007-2010/c-1-71-28800-4605-4606-4609-28126/
    Cheers!!
    DARKRIDER
    Some say "Keep it real!". I say "Keep it DARK!!!!!"
  • grpawalky
    grpawalky
     I have some of these pipes also. They came with my Fatty, but I put the stockers back on with some slip ons. I was a tad worried that there had been no computer upgrade done at the same time as they don't have any backpressure. Be interested to hear others thoughts??
  • the_mongrel
    the_mongrel
    I love the look of the Radius... so have some questions.
    If I whack a set on my new Fatty (2010) do I need to do anything to the air, and or tuner? I intend to upgrade it all in the future, but for now would just like the pipes, and would be keen on your advice.
    -J
  • the_mongrel
    the_mongrel
     Thanks Guys,
    I have a set of Radius 2 in 2 on their way, along with a Kurry Corsair and a TTS.  Yippee!!!
    I will keep you posted.
    Mongrel
  • stilllooking72
    stilllooking72
    Hi Nixon,
    I got the V & H big radius, tuner and breather kit done on my Wideglide before I pcked it up from the Stealer.
    When I first spoke to him about it, he quoted me $2500. Then when it came down to the crunch, the price miraculously dropped $500 .
    As far as noise goes, I wouldn't have bought my wideglide without the exhaust, as it sounds SWEET with it on, and very sad without it.
    Hope this helps.
