Online: Stuart, baldy1450
Change 05 Sporty from carby to fuel injection??
  • Dermie
    Dermie
    The sporty I have has a carby, apparently in the same year they went to fuel injection, can I change to fuel injection easy
  • kingchops
    kingchops
    Dermie,
    2007 was the first year of fuel injected sportsters.  2006 and prior were all carbs.  I've done a lot of reading about Sportsters but I've never heard of a conversion kit for carb to FI.  It would be a big job, the wiring would be the most difficult as you'd need to wire up an ECU, plus injectors and exhaust sensors.  I'd say the cost wouldn't be worth it.
  • Dermie
    Dermie
    Thanks, sort of thought as much but you never know these days what's about.
    I didn't answer since I wasn't sure if there was something new on the market that I hadn't heard about :P
  • Dermie
    Dermie
    Thx for the input, as I said I wuz just thinking
  • Dermie
    Dermie
    Hey thanks Hef that is probably the thing that would really work. Will probably cost 21/2 to 3K installed. I will look at this & work out whether in the next few months I would want a new Sportsta or keep this one with a injection system.
  • rowie
    rowie
    Bite the bullet I reckon and upgrade your bike.
  • Dermie
    Dermie
    Yeah I reckon I might in the short term future, I bought this one (05 Sportsta Custom) at 1,900 kms in Jan & have now got over 13,000kms on it. I am generally very happy with it but it takes forever to warm up & I like to ride it as much as possible, but just dropping down to town at 5kms away for a latte & the thing is still farting & spluttering by the time I get to my favorite cafĂ©!!
  • Dermie
    Dermie
    No it is a2005 sportster & I bought it this January 2010, Actually I made a mistake it was in December 09 that I bought it. It was owned by a lady who got a crook back. I think she wanted a Harely & was told that the "small one" would be the way to go, probably should have got a small bike.
    Digital speedo?? its got a needle that spins around to tell me how fast we are going & a row of led's under it to tell me right or left or whats going wrong!!
    I meant the odometer - if it was digital or the old kind. I can do 1900 kms on a good weekend so forgive me if I'm skeptical :P
  • grafpak
    grafpak
    a mate of mine fitted a mikuni carb to his and made it start and run 100% better..efi wouldn't be that hard to do but you'd need a complete loom/ecu from a written off bike (wreckers would have these by now!)manifold/injectors/a/c backing plate and a month of weekends in the garage..
