Rattle in the rear
  • Finny
    Finny
    Coming home tonight i could hear a rattling, tinni noise coming from the rear? Checked pipes checked some other things but cant find wear. Nothing on idle any ideas
    Finny
  • kingchops
    kingchops
    Finny,
    Might be a good idea to try pusing the bike with motor off and while in neutral to see if there's any sound?
  • Finny
    Finny
    KC just tried that and theres no noise, Pushes easy forward reverse, I was thinking i might check the heat shields but thnks 4 getting back to me
  • Finny
    Finny
    Well you would'nt believe it. My father inlaw put some tools in one of the bags but didnt tell me  the other good thing is there not mine so i scored some tools
  • twincam88b
    twincam88b
