Online: bikenut57, brunosaustryau
Samson Exhaust Systems
  • 07Harley
    07Harley
    Howdy Folks,
    Wanting to know if anyone has had any experience with the Samson Exhaust Brand.
    Im looking in particular at ''Samson Legend Series Rip Saw Exhaust''
    To go on 07 Softail with 103ci S/E Motor.
    Experiences ? Photos ? Aussie Dealers ?
    Anything appreciated.
    Cheers,
    Chad.
  • 07Harley
    07Harley
    No one knows about or has anything to do with Samson ?
  • watto883
    watto883
    mickrod has them on his Vrod ... look in the " show us your bike " in the VRSC section ..... maybe post it there and Mickrod might tell you what he thinks .... from memory i think he said they LOUD
  • 2005 FLSTFI
    2005 FLSTFI
    was looking to get the streetsweepers a while ago, done a search & posted same question on US forum - not good feedback, peeling chrome, manufacture was not up to scratch, no support. This was only them guys experiences though. From feedback I went looking elsewhere
    sorry if I'm disapointing you
  • AJ56
    AJ56
    bloody hanging net
  • Kustomtown
    Kustomtown
    Got samson fishtails (slip on mufflers) on order from the states for my RK.
  • Kustomtown
    Kustomtown
    http://www.tremx.com/SAMSON_TRUE_DUALS_FOR_SOFTAIL_p/samson-pu-1800-0189.htm
  • 07Harley
    07Harley
    Thanks for the feedback fella's.
    From what it seems so far everyone has not had great experience with them.
    Looks like its the V&H series for me.
    Cheers!
    Chad.
  • blueystar
    blueystar
    fittered samson true duels to the finger burner no problems i like the sound better than the 2 in to 1 v@h pro pipe that was fittered
    got them for $650 of some one on this forum brand new
    but it is eraly days to give a report on pipes
  • eddy666
    eddy666
    Got sampson upswept fishtails on my softail and had no probs, been on for a year and its ridden every day to work. Fitted like a glove and sound awesome.
  • Wallah
    Wallah
    I have Samson longtails on my Deluxe off M&M cycles.  There was a defect on the chrome on one of the heat shields, but they sent me a new piece free of charge, including shipping from the US.  Haven't had any other problems with the chrome or pipes.  Easy install and sounds great. Everything is made in china nowadays so we see more & more problems with all products.  I just ordered some chrome bolts from the dealers and a couple had rust under the head.
  • HAMM3Rsix
    HAMM3Rsix
    I run sidewinders on my lo good pipes good tune and loud as old skool
    deebee thats a mean avatar mmmmmm bang bang bang
    theres some photos on my posts
  • CRASHER
    CRASHER
    have samson upswept fishtails and the ceramic coating is fucked...
  • bruk01
    bruk01
    Hi There Chad,
    I hope you went with the Samson pipes mate. I have a set on my '06 Nightrain and I love 'em. Look great, nice and fat chrome is outstanding and they sound awsome. Bit suprised on the negative feedback here.
    Bruk
  • Ando
    Ando
    Fuck mate ya dug this up from the past
    try an intro for a first post
  • bruk01
    bruk01
    No probs,
    Bruce Norman for SA. Just imported an 06 nightrain from the US. Best thing I ever done. Got a great deal and safe as houses. Its my third Harley and I was looking around for some info on the Samson products as I have never used these pipes before. As discussed i am real happy with them. I want to start playing with the fuel injection now. It has a stage 1 filter set up and a re-map I believe but it's never been on a dyno and I'd like to get as much out of the engine in its stock form as I can. I have not had any experiance with the fuel injection before and could use some tips.
    Regards
    Bruce
  • AJ56
    AJ56
    If it has had a remap it may? be ok but if you want to do your own tuning with the EFI then there are plenty of products out there. Have a look in the Tuning Section of this forum, a lot of your questions will be answered there. Me I use the TTS as it gives a lot of options that some of the others don't. Having said that it can be very daunting when starting out. Do your homework and see what best suits. You will get plenty of help here with whatever tuner you get.
  • Zorrohd
    Zorrohd
    Got some Samson Longhorns with fishtails on my Indian chief 2010 black cermaic coated no problems at all. Sound great a bit loud so we fitted the quiet baffles
