UHF installation on ultra classic 2009
  • wayneULT09
    wayneULT09
    How does one add on a UHF radio to the existing sound system?
  • wayneULT09
    wayneULT09
    Hi Raymond, thank you for your reply, will see about removing the screen and looking at the jacks at the back of the radio, will see how I go?
  • Rick1310
    Rick1310
    Wayne
    You could go & check out this site Dale McLean at www.dmme.com.au it may help not sure.
  • CHARLIE
    CHARLIE
    Rick 1310 is on track the person in question makes a complete harness to suit all Ultra's and is simple to fit works well with the Harly head set,i have a GME set on mine.Charlie
  • wayneULT09
    wayneULT09
    Hi, Thank you for your input!
  • Sturgis
    Sturgis
     I have an '05 and have recently fitted a 'Dale McLean' UHF set. It fits above the radio inside the batwing, with the dials/channel changer fitted to the dash. It works through the existing intercom. So you will still have the OEM CB + UHF.  Works very well.
  • wayneULT09
    wayneULT09
    Thank you for the great news, can you still use the exsting PTT button or do they supply their own extra PTT button?
