Online: Humbug, beaglebasher, speedzter
My Rocker with some changes
  • bluerocka
    bluerocka
    This is my Rocker with a couple of mods.....
  • Wallah
    Wallah
     Nice job!
  • Dan
    Dan
    Gday,
    The DG seat really cleans up the look of the bike,
    Got a couple of Q's for ya,
    How much did you lift the tank? and does it expose any wires or the fuel line much after its done?
    thanks, Dan
  • bluerocka
    bluerocka
    Dan, Lifted the tank about 40mm, does not expose the wiring or fuel lines anymore than they where. The tank lift brackets I used had to have additional holes drilled as the tank mount guages would have hit at 50mm holes with the 12 inch Burleigh bars...   The only thing that I think now need to be done is to chrome the top engine mount as that is more exposed...otherwise all good...
  • seagle
    seagle
    How do those BR 2-1 pipes go ? Did u notice much pick up in power? I know they sound good. Neat job on a cool bike.
  • bluerocka
    bluerocka
    PD, I have not noticed that much difference, I must admit though I fill up every couple hundred klms anyway....I also have the flame LED fuel indicators so when there is one light left you know to fill up..not an issue for me...
    Seagle, the pipes where fitted from new so I don't know what the stock ones where like...
    regards
    Greg.
  • clayto
    clayto
    G'day ol mate,
    what mods did you have  to do to the bike when you fitted those sweet 2in1 pipes?- fuel management mod? as i am looking at doing the same thing, i was told i had to add a ECM?? when the pipes were fitted
    any help would be great
    clayto
  • walrus
    walrus
    hi mate i have also a rocker what type of seat is this to sit on the guard as the gaurd moves does this hit the seat when it bounces
    like youre bike welldone
  • bluerocka
    bluerocka
    Walrus, this is a Danny Gray seat from the states...no issue with the guard and is a good ride...cheers
