Online: B0nes
combination speedo/tacho
  • whiteyluvsrum
    whiteyluvsrum
    g'day,
    was just looking through HD parts and accessories and seen the combination speedo/tacho, part number- 74744-08.
    does anyone have it? is it worth getting? comments?
    cheers, whitey.
  • cattleprod
    cattleprod
    Mate, i've got a similar one to that, 74719-07. Albeit not colour backlit. Easy to install and nice to see what RPM's are doing.
  • Purnong
    Purnong
    What's the cost on these things?
    It would be nice to have a tacho
  • cattleprod
    cattleprod
    Purnong i paid around the $400 mark when i got mine.
    Don't know what whiteys got but the part number is softail
  • cattleprod
    cattleprod
    I got mine from MandM had to wait about 3 weeks. Worth it though.
  • cattleprod
    cattleprod
    The picky of Czareks is the same as mine, albeit mines on a dyna.
  • Purnong
    Purnong
    Just had a look around and the one for a Dyna is Part #74719-08 for the Km version
    Chicago HD have them for $399 which seems ok, Damn my wallett has anorexia since buying this bloody bike
  • Deadly
    Deadly
    It appears the -07 part number units will suit my 08 Softail but I was told the LCD panel doesn't have all the functions of the stock item. I desided to wait and see. Now they have released an updated part number ie. -08, but cant provide info on the difference! Any body know???
  • cattleprod
    cattleprod
    Deadly. Wouldn't have a clue really however, with the 07 i can tell you the clock doesn't work or, 6th gear light.
    Both of which i don't give a shit about.
    1) I dont want to know the time when out and about.
    2) If i can't tell the difference between 1st and 6th gear??!!!!......
  • czarek
    czarek
    My speedo combo has 6th gear indicator, however it does not have a clock and distance to empty that the original speedo had.
    I love it anyway
  • Deadly
    Deadly
    czarek,
    Do you if your combo's part number end's with 07 or 08?
  • Deadly
    Deadly
    Todays 'Missing' word is "know".
    Can you see where it should be? You wont win anything but at least my last post will read better
  • czarek
    czarek
    Deadly
    Speedo/Tacho part number I have is:   74719 - 07.
    It is in Km/h and I paid circa $800 through the dealer (steeler).
    It has 6th gear indicator, main odometer and two trip meters. It doesn't have distance to empty and the clock but I can live with (without) that.
  • apatchie
    apatchie
    Pizzlin the only thing I know is the sixth gear light don't work on the 05's my brother told me.
    Phark I think its Dole day.
    Ill go and buy a couple of slabs, two cartons of smokes, then a counterie and have a punt on the gallops or pokies then go to centrelink plead poverty and get an advance.
    My day is planned, just listen to "Blake's Jerusalem" one more time then I'm OFF.
