39mm fork clamps?
  • nhb006
    nhb006
    Guys,
    Anyone know were to get these in Aust. at a reasonable price? - I want to relocated my turn signals off the bars.
  • Brucey
    Brucey
    Hi there NBH yes i am thinking of a set for my iron got any piccys of what you want?? just fitting the DRO scales to my mill so i will be machining a set for myself soon out of alloy and getting them black anodised
    Bruce
    You can get a Clamp that Bolts on the side of the Tripple Tree, There a HD Part. They came on 86 to 2000 Sportsters and Dynas I think.
  • nhb006
    nhb006
    I havent heard of the one you mention walka. - I was after something that would hold them close to the triple trees. - The HD kits I've seen for Sporties sticks the indicators out a fair way.
  • Brucey
    Brucey
    Thats what i am thinking hope this works
    Just knocked up a quick sketch in solidworks
    Bruce
  • nhb006
    nhb006
    They look good Brucey!
    I'm thinging about just trying some 39mm rubberised clamps around the tubes, 5/16 staino bolts & a couple of nuts!
    Cheap, Nasty, but it will work for the time being. - I really want them tight to the tripple trees.
