lowering kits - sportster
  • rockyrob
    rockyrob
    I was checking out lowering a friends nightster a while back,  If you do a search the posts will be there still .  Sportytrace was very helpful advice wise.  Project got put in the too hard basket tho  so nothing ever happened as yet,
  • mintpaul
    mintpaul
    I'm interested is this too but I think the standard shocks will have too much travel and bottom out on your wheel if you use the lowering kit
    Check out the licks 10inch shocks http://www.lickscycles.com/
