Online: speedzter
Pump for Fournales shockies
  • cattleprod
    cattleprod
    Just got one of these hand pumps from cecil cycles in Melbourne. Works upto 30 Bar and is effin brilliant. Small light weight and efficient $58.00 is better than Fournales $270.00.
    www.cecilwalker.com.au/category65_1.htm
    Enjoy
  • cattleprod
    cattleprod
    I should've mentioned it's the BBB Airshock pump with the gauge and swivel head.
  • cattleprod
    cattleprod
    Hehe, ones for sucking the others for blowing...
  • cattleprod
    cattleprod
    Shed.
    These are a great little pump, i've tested these over a 24 hour period at 15 bar. Loss over that time was 1 bar (This is at pump with a blocking nipple fitted). I paid $58.00 including delivery within melb. Also small enough to take with you on a run.
