Online: speedzter
Tools for Cam work on 2005 88ci T/Cam engine
  • gahobbsau
    gahobbsau
    I want to buy, hire or borrow tools for Cam work on 2005 88ci T/Cam engine. I am located on west side of Brisbane.
    I have listed the Georges tools numbers but matching JIMS tools are also suitable. You can see all these at www.georges-garage.com.
    I would welcome any other ideas that you have about whether or not I need all these tools or whether there are other generic tools that can do the job.
    Cam plate - Remove and install
    320500 Cam Tensioner Unloader**
    320520 Cam/Pinion Gear Locking Tool
    320530 Oil Pump Alignment Screws
    Cam plate bearings
    320560 Camshaft Bearing Puller**
    320510 Camshaft Remover and Installer
    Inner cam bearings
    320540 Inner Cam Bearing Puller
    320550 Inner Cam Bearing Installer
    ** If I go with gear drive, then I probably won't need the tools marked with **.
    If you want to see a picture show of the job, including bearing replacement have a look at this link: http://www.harleyhog.co.uk/tensionerinstall.htm There are also chapters on the job in Chris Maida's 101 Harley-Davidson Twin Cam Performance Projects and in the Service Manual.
  • 2005 FLSTFI
    2005 FLSTFI
    I'd be checkin for crank runout first before I even thought about going geardrives. needs to under 0.003"
