Online: speedzter
TORQUE FIGURES
  • jocky
    jocky
    HI GUYS, HAVENT POSTED FOR AWHILE BUT READING THE 2010 HARLEY CATALOG I WAS LOOKING AT THE ENGINE OUTPUTS FOR THE 96 CUBE, AND AM A LITTLE CONFUSED AS TO WHY THEY ARE DIFFERENT.
    EG:FLSTC...117Nm@3200RPM       FLHTCU...131@ 3500RPM   FXDF...127Nm@3500   FXDB...123@3125....ALSO WHY DO THEY QUOTE SOME FIGURES AS EEC/95/1...?  WHAT IS EEC/95/1... IF YOU CAN GIVE ME AN ANSWER WOULD BE GOOD.....
    THANKS JOCKY....
  • ductor
    ductor
    What I'd like to know is the ratio of weight distribution (front load to rear load) of the different Harleys
  • 08custom
    08custom
    I'd say the varience in rpm's has something to do with the difference in torque figs. The two that are both 3500 don't know
  • FLSTC
    FLSTC
    well firstly you have the softtails with counterbalance which reduces TQ compared to rubber mounted motors . as to the differences between the dynas and FLH , i suppose it was justa matter of tweaking the AFR etc as it is a heavier bike ...
  • jocky
    jocky
    THE FIGURES ARE IN THE 2010 HD MODEL LINE UP
  • jocky
    jocky
    CARN,T HELP IT HAVENT GOT AN ANSWER YET ANDO
