Online: John.R, Hilly
Best bike jack in au?
  • ==ShaDoW==
    ==ShaDoW==
    Whats the best bike jack, or the most popular? I have them for my motard but they are all foot operated (ie you stand on it the bike goes up) cant do this with a harley of couse so I am gonna have to buy one.
    Any advice pics would be great thanks.
  • vladt
    vladt
    I bought the Peter Stevens $350 special - Well nothing special indeed.
    If you could afford it, get Handy brand. This is what all the pro's outthere use. Otherwise, I think they all are fairly average.
  • Rooster
    Rooster
    I bought a bike lift from REPCO in town here. $150 on sale. Come round and check it out when you have a chance.
    It might not fit on the dyna without an attachment to mount to the chassis rails ?? Not sure... Check it out anyway.
  • shfunky
    shfunky
    Hey Shadow, I reckon it depends on what you want to do to your bike, I built one of these  http://www.nightrider.com/biketech/bikelift.htm
    It does me, I bought one of the standard type Repco/ Autozone ones and also bought the dyna pads for the frame but didn't like the set up. The $20 one holds the bike steady as and I put 2 ring fittings on it so I could strap the bike too. I use my lift for changing the rear and front tyres and for cleaning the spokes ect.
    Gibo
  • ==ShaDoW==
    ==ShaDoW==
    great info, might try to drop in on Friday Rooster after work, thanks.
    PS shfunky that does look sweet might make one of them up just for a quick lift save draping out a bigger lift and having to jack up etc.
  • ==ShaDoW==
    ==ShaDoW==
    HAd a look at one at repco i think I will go with that one, price was 270, got him down to 220.
