vance &hines big shot exhoust &fuel pack
  • kaboom
    kaboom
     con any one help i am thinking of putting vance &hindes on my 07 road king classic , also does any one  k now how there  fuel pack workes  compered to harley r tuner  or thunder max
  • 08custom
    08custom
    Just my opinion but I put the fuelpak on my old custom with the straightshots, everything was calibrated exactly as per instructions, started the bike and it ran like shit. I took it for a run and what a pig! Decel popping, rough idle just all round bad. Had a mate come round he took it all of set it back up same thing.
    Ripped it off went the Power Commander 3, dynoed never looked back.
  • redrckr
    redrckr
    I just put on my new RockerC all Vance & Hines gear - air filter, 2into1's and fuel pak. Installed it all myself, calibrated the fuelpak with the latest settings off the website and all good. Idles perfect cold or hot, runs so much better it isn't funny and at last sounds and looks the part.
  • 08custom
    08custom
    Glad to hear your new rides keeping you happy, congrats on the purchase. At least you didn't go blue! Maybe mine was just a bad one or something and after going the commander didn't look back.
  • kaboom
    kaboom
    thanks   YOUSITIME  verry helpfullwhat is and who makes TTStuning kit  also what is fp/ XIED COMBO  are you a machanic do youliv in nsw
