Online: Lushy
TTS and the lost MT7 files
  • 2Dog
    2Dog
     Thanks to Scotty and Steve, I got my 06 RG converted to using O2 sensors last summer. The bike now has Supertrapp 2:1 and Doherty power Pac air cleaner and she pulls good for an otherwise stock motor.  So now I want to make some adjustments to the spark table and see why it stalls when it goes into EITMS. After reading the manuals and all the online posts I have a good idea of what to tweak. The problem is that I've had a computer crash since all this was done and now. The original MTE file as well as the MT7 file created at the time are all gone. So I tried getting the map from the ECM but it saves it as an MTE file, which can't be looked at or changed into an MT7 file. The MTE file name tells me what base map it started from but I'd rather not have to do the V-Tune all over again.
    So dose anyone know of a way that I can get the map that's now running in the ECM to edit it?
  • 2Dog
    2Dog
    Crap!
    B'n planning to do the cams and some head work soon. Guess I'll put up with the stalling until then.
  • davidr5577
    davidr5577
    Big thanks to all the learned gents on this forum...
    I installed TTS on my 07 Softail today and made a couple of copies of the MTE file on a USB stick and another computer.
    I installed the QD176-002-B1 and disabled the Active Air/Exhaust. Only done a hundred clicks but bike is smoother and more responsive and not a pop or bang at all.
    This replaced a PCIII which was either dead or dying...
    Now to learn about VTune...
