s100 total cycle cleaner
V2Evo96
Hey Crusty,
Yep S100 is very good and performs well. Personally I found it a bit pricey so I looked for another product. I found "CT-18" at Autobarn, which is a PH neutral, green friendly truck wash. A 1L bottle is about $11 and is concentrated. This stuff works the same way as S100 does-- if you want to try it out sometime you might save some $$$.
I'm still using the same bottle I bought last spring. I use 40Ml to 6 L of water, which is more that the recommended dosage.
Not meaning to hijack your thread, but the cheaper alternative works just as well.......
Fangio
fark man, its so good i drink it...
CT-18 for me too
motor_head
Yep...I'm in the CT-18 club too.
V2Evo96
CT-18 on sale at autobarn in Gippsland at around $23.99 for a 5 Liter bottle.
I rinse several times and wet the ground for a few meters around the bike, then hit it with a high power leaf blower straight after the rinse. Hardly ever touch the bike with any cloth, wash mit, or chamois if I can avoid it. Just need to be careful with the blower around the lower areas and under the bike. Works fine for me...
groover
$23.99 for a 5 Ltr goonie, fark, surley a nice brown musket thats been aging all afternoon would suffice.
