Sucker and a V&^H ProPipe. I;ve used and tuned with the TTS and it runs very well. I have the chance to get a set of SE-255 cams cheap. If I use those cams, do I just start the VTune from where I'm at? Concidering the VTunes I've done? Or do I go for a different starting map and begin again.  I guess my question really is...if the VE tables are correct and I change cams, do I grab a different map and start over. Thanks in advance for any help. Brian " /> Sucker and a V&^H ProPipe. I;ve used and tuned with the TTS and it runs very well. I have the chance to get a set of SE-255 cams cheap. If I use those cams, do I just start the VTune from where I'm at? Concidering the VTunes I've done? Or do I go for a different starting map and begin again.  I guess my question really is...if the VE tables are correct and I change cams, do I grab a different map and start over. Thanks in advance for any help. Brian " />
Online: softfat
Dumb TTS ??
  • slyde1
    slyde1
    I have a 08 police Electra Glide(103"). I've put on a Big>Sucker and a V&^H ProPipe. I;ve used and tuned with the TTS and it runs very well. I have the chance to get a set of SE-255 cams cheap. If I use those cams, do I just start the VTune from where I'm at? Concidering the VTunes I've done? Or do I go for a different starting map and begin again.  I guess my question really is...if the VE tables are correct and I change cams, do I grab a different map and start over. Thanks in advance for any help.
    Brian
  • slyde1
    slyde1
    Thanks all, for the advice. Hopefully I can get them and give em a try.
    Brian
  • Fr3d
    Fr3d
    Map UH205 is already in the TTS cal list for an 08-09. It is for a 103 with 255 cams.
  • WVULTRA
    WVULTRA
    I'd take a close look at the CVO map, UJ205-002!
  • Rider57
    Rider57
    I had better results changing the engine size to 107 then I tried 110. Both worked great.
