Online: B0nes
Irons , Nightsters
  • WWW.AJ
    WWW.AJ
    Just curious folks the Irons and the Nightsters look pretty dam good but tell me --- do they have any suspension or do the ride like my brides low , a brick truck ?
  • WWW.AJ
    WWW.AJ
    Our Low which is piloted around by the boss at 52 kgs has no problem but me at 75 kgs ' Scarey ' much prefer my Roadster for a bit of suspension travel and ground clearance
  • TC883
    TC883
    Same here with bottoming out the front if you hit a driveway too fast. I am using all of the travel in the rears, but so far no problems with bottoming out. Mine is an Iron, I weigh 70kg.
    BTW how do I know how much travel I am using on the rear ?- I put a cable tie on the shock shaft and rode around for a while. The final position of the cable tie shows how much travel you are using....old racers trick. I would like to lower the rear of mine for cosmetic reasons, but am happy with the ride & handling and already run out of cornering clearance all the time. Lowering will only reduce cornering clearance, so gunna leave it alone for a while I reckon. TC
