The New 48
  • Mr F
    Mr F
    Does anyone know when this new bike will be available in Australia? It has been launched in the UK for 7,995 pounds and in the US for $10,500.....we will probably have to wait ages and then pay $17-18,000!!!
    I read October/November - with the usual subject to change BS.
  • twincam88b
    twincam88b
    they look shit hot I rekon...
  • shfunky
    shfunky
    They do look good, I've been wondering if that front wheel/tyre setup would fit on my Streetbob.
  • kingchops
    kingchops
    They do look good. I reckon they'd look a whole lot better with a 49mm front end. The forks look too skinny with that fat tyre on there. Aside from that still a good look.
  • shfunky
    shfunky
    Thanks for the tip Alby, still you would want to be sure it fits once your done, wouldn't want to reverse engineer it if it didn't fit. I suppose the first thing to do is check the size of the trees on the 48 and see if their the same width as the bob. The 48 has a 130 tyre on a 16" rim. (MT90 tyre)
