Online: Humbug, Ultramick
Tribar LED brake light
  • dodge
    dodge
    Just fitted up a HD Tri bar tail light to the FXSTC and for anyone considering the same - it fitted up very well and is an extremely simple job.
    Good destructions and basically unbolt old light and housing - bolt in new housing - plug in new tail light - done.
    Comes with everything required for number plate and I like the fact that there is no wiring work required - ie push plug into socket.
    As usual with anything Harley - expensive at $385 (yes I know probably many cheaper on the net etc etc but this was my usual impulse buy while I was walking around the shop!!).
    Quality product so far.
    Dodge
  • Burnzi
    Burnzi
    got a pic mate? is this the 1 that flashes the brake light when u apply the brake?
  • dodge
    dodge
    And you don't have to put on that poxy red reflector just above the plate (hate reflectors!!!!!!)
  • Harvey
    Harvey
    And jam your number plate right up 1. to show more tyre and 2. sneak thru over head toll cameras
  • benton007
    benton007
    looks good but will it work with the bobtail fender rack?
  • Burnzi
    Burnzi
    Thanx for the link Dodge. The one I saw on the Immortals rol the dice run Flashes several times when you apply the brake, I think it incorporated a number plate holder as well, like the look of urs though too
  • benton007
    benton007
    thanks burra, i already have the rack, so if i get the light ill have to get the bracket too.
  • dodge
    dodge
    Burnzi - this one has the plate holder as well - the bracket you see in the pick below the light comes with the kit and is where your plate bolts onto.
    Burra - great price at $210 - I always pay a price for my impatience! - Gotta have it now!!!
  • Hooky
    Hooky
    This is my Tri-Bar from behind, in idle.
  • Wildturkey
    Wildturkey
    tri bar light is a sealed unit and some are starting to fail due to aus road conditions
