dyna rear end
  • wilso
    wilso
    im looking to get a fatter rear end under  my 99 wideglide - even a 200 would do me, and as the minister for finance (wifey) scoffed at my quote from chopperworks for approx $6000 plus wheel for a 240 , would it be possible to take the rear swingarm from a later 07-09 dyna and fit it with guard and wheel without too much dramas?
    cheers for the help brothers.....
    wilso
    Why would you go to Chopperworks, I have kits starting a $2700.00
  • FastHarley
    FastHarley
    The wider the tire the more rolling resistance it produces, the more HP is requires to turn it, and the heavier the tire becomes.  Of course if you are able to spin the tire in the corner by throttling up than by all means increase the tire patch size.  If you wish to do it for looks than that is up to you.
  • wilso
    wilso
    if you dont mind angry,could you check yours? and let us know, cheers mate
    walka , where do i find out more info on your kits? cheers
    wilso
    Call me 03 8405 9212
  • wilso
    wilso
    yeah thanks for checkin angry , i checked a guys 07 dyna at work 2day and his swingarm is mounted off the motor, so no good for me. i'll have to chase up with walka , as a long term option, but for now i'll concentrate getting my bike all the way i want then fatten up the rear last of all.
    cheers everyone for their help on this.
    wilso
